Current time: 16/10/2026, 10:11 Hello There, Guest! (Login — Register)
Halton Transport
RE: Halton Transport
(14/09/2013 06:21)M60lad Wrote:  Not sure which one it was but one of Haltons MCV Evolutions was causing problems in Queen Square Bus Station yesterday afternoon after it broke down on the alighting only stand
Breaking down at the alighting only stand causes a lot less problems than if it had broke down on the other side.
I knew it was only a matter of time before one broke down! The majority sound so unhealthy!
Not living in the area but I wonder whether any of Haltons services have been affected by the incident on Runcorn Widnes bridge today, apparently its still ongoing from 11:50 this morning, good job this wasn't a weekday else it would have been gridlock in the area
(15/09/2013 19:14)M60lad Wrote:  Not living in the area but I wonder whether any of Haltons services have been affected by the incident on Runcorn Widnes bridge today, apparently its still ongoing from 11:50 this morning, good job this wasn't a weekday else it would have been gridlock in the area
Halton don't operate any services across the bridge on Sundays as the 62/A is Mon-Sat, and the hourly 61 runs only to Widnes.
I've heard there was incident of someone scaling/ planning to jumpoff the bridge, but the bridge was also kept closed for "high winds"
#13 on the 27
(18/09/2013 07:41)Fox Wrote:  #13 on the 27
You will see a few vehicles on the 27.
The first trip today (0711 from Weates Close) was done by #36, which then went on to 61's I think.
But Solo #59 was on there for most of the time.
I'm not a fan of the 27(A) arrangements.
I'd prefer the 26(A) to cover the part of the route particular to the 27A, with the 27 being half-hourly.
Much time seems to be being lost in the afternoon peak on this route, and the extra mileage the 27A requires doesn't seem to be helping.
Though I do admit that I am not a regular in those parts so I might just have had bad luck so far.
Yep 36# ended up on the 61.
A bit of trivia in that an enviro200 with "Widnes 14F" on the front will display "14F Liverpool" on the side.
(20/09/2013 15:54)Fox Wrote:  A bit of trivia in that an enviro200 with "Widnes 14F" on the front will display "14F Liverpool" on the side.
It's a funny one that, I have noticed it myself.
Just want to point out that 32 appears to have recived route branding for the 62/62a. Didn't get a good look at it but it is quite small but as much as routw branding can be criticized as unprofessinal, it is actually quite a nice touch. Dont know if any other busses have it, but if there is I would imagine it to be the other Marshall Capitals with LEDs. So next time you see 32, make sure you look at the first nearside window.
