Current time: 20/11/2026, 02:01 Hello There, Guest! (Login — Register)
Northern Rail
RE: Northern Rail
Have 319 366 and 319 379 entered service yet as I haven't seen them on the Wigan line?
RE: Northern Rail
As of yesterday they hadn't.
SD.
RE: Northern Rail
(25/11/2015 19:33)knutstransport Wrote:  Rumours are circulating that Govia's bid was substandard and rejected, while Abellio's numbers didn't add up in their train plan meaning Arriva will be the likely winners.
With TPE all bids apparently were good enough and First are rumoured to be favourites.
You should tread carefully here , in particular with the TPX bids as both First and stagecoach are listed companies and any leaking of information whether it comes from rumours or not can be commercially damaging.
RE: Northern Rail
In his defence they are all over the internet and may not be true for all we know...
RE: Northern Rail
(26/11/2015 08:46)Sprinterdriver Wrote:  As of yesterday they hadn't.
SD.
Thanks SD. They may be being held back for the timetable change when the Warrington Bank Quay service becomes electric.
RE: Northern Rail
(26/11/2015 11:14)jtd508110 Wrote:  In his defence they are all over the internet and may not be true for all we know...
Indeed. There are already on forums and sites which get a lot more views than this one. The Govia claim has even been posted by Modern Railways writer Tony Miles under his real name so he must be confident about that.
RE: Northern Rail
319379 in service today on the Preston - South Parkway run. Seen on the 15:39 from LIV - LPY
RE: Northern Rail
(26/11/2015 18:19)jtd508110 Wrote:  319379 in service today on the Preston - South Parkway run. Seen on the 15:39 from LIV - LPY
Thanks for the confirmation jtd508110. It has seemed a while since they were reported at Allerton, hence my query, so again thanks.
RE: Northern Rail
No problem! Still no sign of 366 though.
RE: Northern Rail
It wasn't in the spot it has been for some time when I went passed Allerton earlier tonight, so maybe it will be out shortly?
SD.
