Current time: 17/10/2026, 18:28 Hello There, Guest! (Login — Register)
Arriva Click Coming To Merseyside
RE: Arriva Click Coming To Merseyside
(17/04/2019 06:24)Penny Return Wrote:  They also have their own drivers.how many buses are used on the rail contract ? as buses
layover here,have seen a few when going to Garston for 6F70 when it runs
Bear in mind ArrivaClick buses also use South Parkway for breaks etc.
For the main part yes, however Birkenhead is the only garage that i'm aware of, which employs set click drivers but also have recently trained up a couple of drivers as 'Click Relief'. Ie mainly on standard routes, but able to cover click when required.
(17/04/2019 13:03)L401CJF Wrote:  For the main part yes, however Birkenhead is the only garage that i'm aware of, which employs set click drivers but also have recently trained up a couple of drivers as 'Click Relief'. Ie mainly on standard routes, but able to cover click when required.
All 3 depots have dedicated Click drivers that can only work on Click services. You are correct that there are 3 drivers in Birkenhead that have been trained for use as required on an occasional basis.
There is also possibility that Click drivers can operate from any of the 3 Depots.
(17/04/2019 22:33)The Falcon Wrote:  All 3 depots have dedicated Click drivers that can only work on Click services. You are correct that there are 3 drivers in Birkenhead that have been trained for use as required on an occasional basis.
Sorry Reading back that i wasn't very clear, I mean Birkenhead are the only depot who have relief drivers as well as dedicated click drivers, not that Birkenhead is the only depot to have dedicated drivers!
1034 Carries it's number
1036 1037 do not
Not good enough Huh
Cheers
Rob Day
Formerly
51537
(27/04/2019 13:49)Penny Return Wrote:  1034 Carries it's number
1036 1037 do not
Not good enough Huh
The majority of 1030 to 1039 don’t carry fleet numbers but this will be sorted this week.
Also some inconsistencies with the destination blinds with uppercase and lower case arriva click of Arriva Click being used, again this will be sorted this week
(30/04/2019 22:29)The Falcon Wrote:  The majority of 1030 to 1039 don’t carry fleet numbers but this will be sorted this week.
Thank you for the info, much appreciated
Cheers
Rob Day
Formerly
51537
1018 is no more after being smashed into on Tuesday night in Hunts Cross by a stolen car
Will the incident with 1018 leave Arriva Click short of vehicles? And will 1018 be eventually replaced in the short term and if so by what?
(04/05/2019 05:27)M60lad Wrote:  Will the incident with 1018 leave Arriva Click short of vehicles? And will 1018 be eventually replaced in the short term and if so by what?
Would think the insurance would mean a replacement vechicle
Cheers
Rob Day
Formerly
51537
