Current time: 29/11/2026, 13:32 Hello There, Guest! (Login — Register)
Manchester bus franchising
RE: Manchester bus franchising
Does Tfgm has to issue permits to out of area services running into Gtr Manchester? as like take the 125 they could say no turn round at Horwich or you have to take our fare table and give us a cut.
(29/12/2022 19:05)Barney Wrote:  Prior to the formation of the PTEs in 1969, local agreements crossing municipal boundaries were commonplace. Within Merseyside, Ribble and Crosville services were limited as to where they could pick up and set down as was the the joint services between Birkenhead and Wallasey Corporations on the Wirral. Someone with a good memory will confirm that this was the case in Manchester.
In 1969 Liverpool and Manchester were in Lancashire, while Stockport and Birkenhead were in Cheshire. Wasn't the 'Greater Manchester' PTE originally called SELNEC, effectively making it a cross boundary passenger executive?
I suspect that routes such as the 125 and X43 will require some sort of agreement as is the case with certain London Buses routes that operate beyond the TfL boundary.
As for "Burnham", he has promised to see out his tenure as Mayor of Greater Manchester but I suspect that you will need to focus your attention elsewhere after that.
Yep pre PTEs, mostly Company buses, with Crosville in particular were heavily restricted into how they operated in Corporation areas often only being able to set own inward & pick up outward to/from a point on the edge of the Corporation operating area, when operating in a Corporation area. Wirral had a lot of waste because of Wallasey/Birkenhead & Crosville routes duplicating each other, that it took 10 years after the PTE was formed to finally integrate the old Corporation & Crosville services
Once the PTE came in, they did away with the restrictions, but created limited stop instead, Merseyside was Merseyfare branded stops were Crosville stopped
TFL has commercial routes into its area, they have an agreement to operate into the TFL area, most of the commercial routes are around Heathrow, & Uxbridge, although other commercial routes do operate to some of the other towns inside the TFL boundary
Manchester Evening News reporting that First Manchester have lost the Vantage services and that they will come under the new contracts won by Go North West.
https://www.manchestereveningnews.co.uk/...d-25865786
Also, seen online is a page from a document indicating which services that Diamond will operate from their new Eccles depot from September 2023, while explaining some details about services operating from Go North West's depots in Bolton and Wigan.
[Image: 5641d008-b6ea-4105-850a-84c12d2fb8fd-jpeg.4356600]
Looking at what's been reported, these could be the routes/operators in the Wigan and Bolton areas from end of September 2023. May be a question mark of what happens to some services currently operated from depots in Bolton by Arriva and Vision Bus outside of the Bolton and Wigan areas.
Go North West
  • 1/2 Wigan-Highfield Grange
  • 3/4 Wigan-Norley Hall
  • 5/6 Wigan-Beech Hill
  • 7 Wigan-Bolton via Westhoughton
  • 8 Bolton-Manchester via Farnworth, Kearsley
  • 8 Wigan-Leigh via HIndley
  • 9 Wigan-Leigh via Platt Bridge
  • 10/10A Wigan-Leigh via Ashton-in-Makerfield
  • 20 Bolton-Trafford Centre via Little Hulton
  • 21/22 Agecroft/Bolton-Trafford Centre via Swinton
  • 34 Leigh-Manchester via Worsley
  • 36 Bolton-Manchester via Little Hulton, Walkden
  • 37 Bolton-Manchester via Farnworth, Walkden
  • 163 Bury-Manchester via Heywood
  • 362 Wigan-Chorley
  • 471 Bolton-Rochdale via Bury
  • 472/474 Bury-Ramsbottom
  • 524 Bolton-Bury via Radcliffe
  • 575 Bolton-Wigan via Horwich
  • 582 Bolton-Leigh via Atherton
  • 635 Wigan-Shevington
  • V1 Leigh-Manchester Royal Infirmary via Guided Busway
  • V2 Atherton-Manchester Royal Infirmary via Guided Busway
  • X22 Bolton-Trafford Centre Express
Diamond NW
  • 29 Boothstown-Salford Quays via Walkden
  • 65 Eccles-Westwood Park
  • 66 Eccles-Prestwich via Swinton
  • 70 Eccles-Salford Shopping Centre
  • 74/75 Salford Shopping Centre-Agecroft
  • 79 Salford Shopping Centre-Stretford
  • 126 Leigh-Trafford Centre via Astley
  • 129 Farnworth-Higher Folds via Walkden
  • 132 Wigan-Trafford Centre via Atherton
  • 507 Bolton-Harwood
  • 511 Bolton-Bury via Withins
  • 512/513 Bury-Farnworth via Radcliffe
  • 516 Leigh-Horwich via Westhoughton
  • 521 Little Lever-Blackrod via Westhoughton
  • 525/527 Bolton-Hall i'th' Wood circulars
  • 526 Bolton-Smithills
  • 533 Bolton-Egerton via Bromley Cross
  • 535 Bolton-Belmont via Astley Bridge
  • 537 Bolton-Andrew Lane via Astley Bridge
  • 541 Bolton-Toppings via Bromley Cross
  • 544 Bolton-Little Lever
  • 557 Ringley Fold-Royal Bolton Hospital via Farnworth
  • 559 Bolton-Ashton-in-Makerfield via Westhoughton
  • 573/574 Bolton-Ladybridge circulars
  • 583 Leigh-Tyldesley via Atherton
  • 584 Leigh-Crankwood
  • 588/590 Leigh-Lowton
  • 594 Leigh-Tyldesley via Astley
  • 596 Leigh-Laneside
  • 597 Leigh Infirmary-Leigh Sports Village via Leigh town centre
  • 634 Wigan-Castle Hill via Hindley
Arriva
  • 34 Leigh-St Helens via Newton-le-Willows
  • 320 Wigan-St Helens via Ashton-in-Makerfield
  • 352 Wigan-St Helens via Orrell
  • 360 Wigan-Warrington via Newton-le-Willows
  • 375/385 Wigan-Southport via Skelmersdale and Ormskirk
  • 395 Wigan-Skelmersdale
Merseytravel
  • 156 Garswood-Lea Green via St Helens (Hattons - Monday-Saturday daytime)
  • 156 Ashton-in-Makerfield-St Helens (HTL Buses - evenings/Sundays)
  • 157 Ashton-in-Makerfield-Rainford Station (Cumfybus)
  • 602 Ashton-in-Makerfield-Newton Hospital (HTL Buses)
Stagecoach
  • 38 Logistics North-Manchester (presumably taken over in 2025)
  • 113 Wigan-Preston via Leyland
  • 125 Bolton-Preston via Chorley
  • 127 Middlebrook-Chorley via Adlington
Transdev
  • 1 Bolton-Blackburn via Darwen
Travel Assist
  • TA1 Darwen-Harwood
  • TA2 Darwen-Bury
Warrington's Own Buses
  • 19 Leigh-Warrington via Culcheth and Croft
  • 22 Warrington-Ashton-in-Makerfield via Newton-le-Willows
  • 28/28A/28E Leigh-Warrington via Culcheth and Birchwood
Unknown
  • 1 Bolton-Egerton (evening journeys - possibly still Vision Bus)
  • 10 Brookhouse-Manchester via Eccles (possibly could stay at Arriva's Bolton depot or move to Wythenshawe depot)
  • 22A Wigan-Warrington via Newton-le-Willows (evening/Sunday journeys - possibly still Warrington's Own Buses)
  • 94 Bury-Cheetham Hill (possibly still Vision Bus)
  • 480 Bolton-Bury via Harwood
  • 501 Johnson Fold-Farnworth via Bolton (possibly Go North West)
  • 520 Bolton-Westhoughton (possibly Go North West)
  • 534 Bolton-Oldhams Estate
  • 561/562 Bolton-Withins (possibly Go North West)
  • 571/572 Bolton-Great Lever (possibly Go North West)
  • 613 Wigan-New Springs
  • 630 Wigan-Platt Bridge
  • 639 Wigan-Worsley Hall
  • 640/641 Wigan-Standish circulars
Arriva have already made a decision that they would not be bidding for any tenders in the Bolton area. They’ve also stated that they will consider offers for the Bolton depot, alternative option is to close the site.
Would commercial services run from outside the franchised areas that operate the same route as franchised services within the area have to change, ie services from Southport, Preston, Warrington or St Helens.
(30/12/2022 19:25)SF07 Wrote:  Go North West
  • 362 Wigan-Chorley
I thought the 362 was going to Stsgecoach in Chorley & not go north west
Also surly X39 would go to GNW
I also wonder if any queens rd routes such as 135 & 95, 97, 98 routes will move to Bolton Depot?
(31/12/2022 18:33)CX06 BHE Wrote:  I also wonder if any queens rd routes such as 135 & 95, 97, 98 routes will move to Bolton Depot?
Nothing will change at Queens road until 2025. I wouldn’t have thought they could just move routes to another depot as it will no longer be up to them.
The 135, 95,97,98 will fall into the ‘city centre’ package.
(31/12/2022 22:51)Mayneway Wrote:  Nothing will change at Queens road until 2025. I wouldn’t have thought they could just move routes to another depot as it will no longer be up to them.
Ah yes of cause i was mearly thinking of dead millage etc
It does seem a lot for Go Ahead to be running. Hope they're capable and there are smooth transitions etc. See what happens from 2025 anyway.
