Current time: 06/11/2026, 08:50 Hello There, Guest! (Login — Register)
PO62MGJ 36806 and PO62MKA 36808 are now with Chester Depot, previously with Rock Ferry Depot so i presume Chester is getting more Enviro200's and possibly Enviro300's?
(13/10/2021 10:34)chesterbuses21256 Wrote:  PO62MGJ 36806 and PO62MKA 36808 are now with Chester Depot, previously with Rock Ferry Depot so i presume Chester is getting more Enviro200's and possibly Enviro300's?
Is Rock Ferry getting anything in return?
(13/10/2021 11:57)lcm453 Wrote:  Is Rock Ferry getting anything in return?
36806 was sitting in the middle of the bus station this morning but not seen 36808 that's in local livery
(13/10/2021 07:34)wirralbus Wrote:  What should be happening is one of two things , either they implement an emergency timetable which is hard on a joint QBP route because it becomes unbalanced , or at best try to cancel the same services each day.
At the moment every days cancellations seem to be slightly different , doesnt really help the customers plan there day around the services that will be running .
Latest rumour is that LS are taking over the majority of the Heswall route from 24th October
(13/10/2021 12:24)PAUL2511 Wrote:  36806 was sitting in the middle of the bus station this morning but not seen 36808 that's in local livery
I saw 36808 yesterday on 51/9's, its in the stagecoach livery, wasnt in local
(13/10/2021 16:20)chesterbuses21256 Wrote:  I saw 36808 yesterday on 51/9's, its in the stagecoach livery, wasnt in local
Bustimes.org says otherwise its in local livery according to that if its not then someone been f##### a out with it
Unfortunately not as simple as that as it depends on the rota and which drivers fail!
the problem with woodchurch road is if u work in liverpool your sort of buggered by them dropping services, be better to drive than rely on the bus now. but i know some don't have to luxery off a car
Former Rock Ferry resident 27256 was noted just inside the depot freshly repainted into the new local livery this afternoon.....
HTH
Finally Stagecoach have come to there senses with revised timetables for the X1 , 1 , 41 ,42 , 471 and 472.
Stagecoach will no longer operate the 472 and provide 1 journey each hour each way jointly Monday to Friday with Arriva on the 471 this service is every 30 mins. On Saturdays it will be hourly with no Arriva Participation on the route.
