Current time: 03/11/2026, 21:20 Hello There, Guest! (Login — Register)
If Chester is going to take on the 1 or X1 solely then the Timetable would have to be heavily redrawn from what is operated at this moment as vehicles would be finishing at night at the opposite end of the route .
So probably earlier last services from Chester and consequently later last services to Chester.
(22/12/2025 21:42)wirralbus Wrote:  If Chester is going to take on the 1 or X1 solely then the Timetable would have to be heavily redrawn from what is operated at this moment as vehicles would be finishing at night at the opposite end of the route .
I was told Rock Ferry is being retained by Stagecoach for 1/X1 and contracts such as Twelve Quays and the hope University buses also as a paint shop
The 1/X1 will be split better with Chester under a permit from Merseytravel so can operate into the franchised area
Bee Network 27625 noted in the yard at Rock Ferry this afternoon.....
Attached File(s) Thumbnail(s)
Does anyone know why Stagecoach buses do not appear on the buses map at present, please?
(06/01/2026 10:07)lcm453 Wrote:  Does anyone know why Stagecoach buses do not appear on the buses map at present, please?
If your referring to bustimes.org it's working fine
(06/01/2026 10:44)KX03 KYY Wrote:  If your referring to bustimes.org it's working fine
On bustimes, Rock ferry’s 471/472’s 38’s, 41’s 42’s, 16’s 16A’s and 17’s aren’t tracking but 1’s and X1’s are
(06/01/2026 11:47)chesterbuses21256 Wrote:  On bustimes, Rock ferry’s 471/472’s 38’s, 41’s 42’s, 16’s 16A’s and 17’s aren’t tracking but 1’s and X1’s are
Including some buses masquerading as being on 1/X1 (see what 15740 is up to).
Can see that the X1 frequency is being reduced back down to hourly later this month. Assume that the Chester workings are being dropped?
(12/03/2026 19:15)anw2015 Wrote:  Can see that the X1 frequency is being reduced back down to hourly later this month. Assume that the Chester workings are being dropped?
It could either be Chester’s workings being dropped or Chester and Rock Ferry will operate 2 workings each, if that is the case, Chester will need to get 2 or 3 deckers for it
The 1 is being altered to every 20/40 minutes, here's the new 1/X1 timetable
https://tiscon-maps-stagecoachbus.s3.ama...9Mar26.pdf
User(s) browsing this thread: 35 Guest(s)
