Current time: 17/10/2026, 10:27 Hello There, Guest! (Login — Register)
Arriva North West - Bolton Depot
RE: Arriva North West - Bolton Depot
As well as a 7 day service don't forget Diamondbus also have the tendered evening service now so a lot of passengers will be using them now over Arriva.
Also deckers on most 575s wont happen due to the interworking with 362 in Wigan which goes under Coppull railway bridge, not to sure if the duties are still the same but there's only a select few 575s that actually do go to Wigan and back as 575s without going onto 362
(02/07/2015 19:10)Gillmoss 0324 Wrote:  or a Welsh depot like Rhyl/Bangor especially to replace 4186-91 which are now 14 years old and coming towards the end of the usual 15 year old limit for schools. They could also become open toppers and be fairly modern replacements for the fleet based at Rhyl and some DLP's have been converted for this use by The Original London Tour.
There is a no age restriction on age work that the Lowlanders do at Bangor, remember they not long replaced P/R reg Volvo Olympians. Rhyl uses 4191 generally on a M to F, P&R for Ysbyty Glan Clwyd Hospital. The 15 year rule is generally for tendered services on Merseyside but the company aim to cull most stock when it reaches 15 years old. Correct me if I'm wrong.
Service 537 on VOSA for Cancelation from 30th Aug, Apparently the 715 change is the Service getting cut back to run Bolton - Westhoughton only
2563 has been Withdrawn from Service, 2564 and 2565 are also due of in the very near future. Makes little sense as it was not long ago 2565's Fire damage was repaired!
(07/07/2015 20:45)bolton bus basher Wrote:  2563 has been Withdrawn from Service, 2564 and 2565 are also due of in the very near future. Makes little sense as it was not long ago 2565's Fire damage was repaired!
Is 2564 still off the road?
2564 and 2565 are still in Service, Apparently there could be a Pulsar due as 2565's replacement at end of July
2232 X232 ANC is due of the road back end of this Month as its MOT is up as they dont want to put it through another
In the papers today is confirmation that Services 535 Bolton - Belmont and 537 Bolton - Andrew Lane are to be Withdrawn from 30th Aug. I dont know how the 535 has lasted this long as you where lucky to pick anyone up between Belmont and The Pineapple (Where the 535 joins up with the 534 and 537) As for the 537 Passenger numbers have dropped very quickly over the last 2 Years as back then Andrew Lane had 4 Buses an hour, an Hourly 537 Service and a 20 min 538 Service
Here is the Article - http://www.theboltonnews.co.uk/news/1341...?ref=fbshr
After picking up a fault (Break Related) 2232 has been Withdrawn
Due to go anyway, so no surprise and another dart thankfully bites the dust.
