Current time: 29/11/2026, 11:35 Hello There, Guest! (Login — Register)
indeed MPTE 1955 also that 356/892 does it even still run
(12/08/2013 17:54)E208 WBG Wrote:  indeed MPTE 1955 also that 356/892 does it even still run
Absolutely no idea. I think the 356 still does run, whether stagecoach still do I wouldn't know. Have a feeling that they do.
Interesting. Do the drivers do all of the routes or do they tend to stick to a limited number of runs?
Unless your on spare rosta they tend to stick to certain routes or roads as they call them.
Interesting. Quite different to most other operators then who want you to learn all of the routes such as Network Warrington and Halton...
33179 is on 76 lates and 17201, 269, 325 and 331 are on 82\86 lates
Gillmoss are still doing the 356 under contract to Merseytravel with 2 M-F morning journeys
http://www.merseytravel.gov.uk/travellin...02007).pdf
Hard to think Liverline (North Western)/Arriva NW/CMT/GTL used to run a proper Mon - Sat service on the 356 although they never seemed massively used back then.
GM is also doing some of the jorney's on the 892 with Ace Travel hope this helps.
http://www.merseytravel.gov.uk/travellin...02012).pdf
I thought that they might still be doing the 356, I remember North Western doing a proper service, used to be my way of getting from Kirkby to work in Bootle back then, very handy it was, they used to use those OOR-R (something like that anyway) nationals that had been repowered on them.
17272 (HSV194) on the 76 this evening. Several Tridents out and about on the 86/82 lates again - potentially a slight change of policy from Gillmoss? About bleeding time.
Do the Gillmoss vehicles use the same wayfarer machines as Arriva?
