Current time: 17/10/2026, 10:27 Hello There, Guest! (Login — Register)
Arriva North West - Bolton Depot
RE: Arriva North West - Bolton Depot
(08/08/2015 01:17)bolton bus basher Wrote:  If your going from Bolton - Wigan you also have the 540 and 575 Services as well
I forgot about the 540, although last time I went on it most services terminated in Westhoughton (only B7RLE's seem to go any further) I'm not sure what the frequency of full line services are now. The 575 leaves the S1 boundary near Blackrod.
(08/08/2015 18:34)VolvoB10M Wrote:  I forgot about the 540, although last time I went on it most services terminated in Westhoughton (only B7RLE's seem to go any further) I'm not sure what the frequency of full line services are now. The 575 leaves the S1 boundary near Blackrod.
Ive used a system1 many a time on 575 without any issues,and I know others also use s1 on it as well,because it starts and ends in the s1 boundry your okay using them
(08/08/2015 19:44)Wright Eclipse Wrote:  Ive used a system1 many a time on 575 without any issues,and I know others also use s1 on it as well,because it starts and ends in the s1 boundry your okay using them
I have seen with other routes (non-Arriva) that do a similar thing but you could use the operator's saver tickets but not S1 over the affected areas so I presumed 575 has the same rules.
(08/08/2015 20:19)Dentonian Wrote:  If your journey starts and finishes inside GM, there should be no problem at all
Does this include routes where there is an alternative run by the same operator?
I dont think the 575 leaves Greater Manchester anywhere so should be valid at all stops anyway
(08/08/2015 23:37)T42 PVM Wrote:  I dont think the 575 leaves Greater Manchester anywhere so should be valid at all stops anyway
I tried checking the Wigan north map on the TFGM site but my internet provider has reduced speed to a crawling pace so loading .pdf files is not currently possible, everyone else should be able to see it: http://www.tfgm.com/journey_planning/Doc...-North.pdf
Am currently looking at the map and that backs up what am saying, stays within Greater Manchester
(09/08/2015 22:45)T42 PVM Wrote:  Am currently looking at the map and that backs up what am saying, stays within Greater Manchester
Thanks, my connection speed is appalling.
Does anyone know the current status of 4178 after it's bridge accident in Eccles? It's the only DLP I've not done and the damage from what I've seen online didn't look too bad to repair. Also does anyone know if it will be allocated to a different depot if/when it's fixed? Thanks.
(12/08/2015 14:40)Gillmoss 0324 Wrote:  Does anyone know the current status of 4178 after it's bridge accident in Eccles? It's the only DLP I've not done and the damage from what I've seen online didn't look too bad to repair. Also does anyone know if it will be allocated to a different depot if/when it's fixed? Thanks.
It under repair it will then be moving to a Merseyside Depot
