Current time: 05/11/2026, 08:18 Hello There, Guest! (Login — Register)
[Archive] Arriva North West - Birkenhead Depot
yeah they have the most tacho fitted veichles in merseyside so they tend to do majority of the private hires if not all,except the one speke use to do every weekend for a morris dancing troop.
Lee Laird Street have done Private Hires for many years now
Mersey Ferries is one of the Main Private Hires LS do. 4002 had a tacho fitted when it arrived at Speke for Private Hires
It was quite common to see 3304T out and about too with ribbons from mirrors to grille with a bouquet of flowers on the front and 'Wedding Bus' on the destination- back when LS still had proper buses that is.
Its just being in the right place at the right time, and knowing the right people to get a photo!
Correct Luke. schools and rail reps are also classed as private hires
(28/10/2012 15:39)J654UHN Wrote:  Correct Luke. schools and rail reps are also classed as private hires
That means there is also a private hire fleet at Bootle which also should have a rail replacement fleet .
(28/10/2012 16:23)wirralbus Wrote:  That means there is also a private hire fleet at Bootle which also should have a rail replacement fleet .
Having seen the allocations from Bootle in the past they tend to vary from what ever is left in the depot, like earlier in the year they where using Darts, VDL's and Enviro400's on the Southport line.
At the moment most emergency rail replacements seem to be on the Wirral between Hooton and Chester / Ellesmere Port and Birkenhead North and New Brighton lines .
On the Northern the most prone areas seem to be Hillside - Southport in that case its ask Bootle first then go cap in hand to the other depots.
rail replacement and normal schools dont come under the tacho rules as they dont require a tacho fitted but if its a school trip then it would need one fitted.
3301t used to be a regular on private hires, being lent to other depots.
Tacho buses are:
2344
2345
2435
2436
4002
4200
4201
4202
4204
4205
4412 - 4422
Take a walk on the wild side of life, life!
