Current time: 02/06/2026, 21:13 Hello There, Guest! (LoginRegister)
Merseytravel: Bus service Consultations
RE: Merseytravel: Bus service Consultations
(06/12/2019 18:17)St Helens Rider Wrote:  Sounds like the usual Arriva practice of death by a thousand cuts. Also make the service as useless as possible in order to reduce usage in order to cut it altogether.
Does sound right for Arriva to do it this way so they can axe the service altogether as look at how they done the 21 Halton Hospital - Chester, they cut that back to Helsby and then axed it altogether as very little people where using it
Find all posts by this user
Results of the X1 consultation now up. service will NOT be withdrawn. Instead, it will operate every 40 mins Monday-Saturday daytime with extra services in the peaks
https://www.merseytravel.gov.uk/about-us...ation.aspx
I see Merseytravel has revamped there website, timetables are now listed as well as being able to do search, some Halton routes are listed too
(13/01/2020 20:29)MTL0201 Wrote:  I see Merseytravel has revamped there website, timetables are now listed as well as being able to do search, some Halton routes are listed too
Looks great and a massive improvement in my opinion!
A couple of small teething issues, but that is of course to be expected.
Consultation has been opened on proposed change to service 91/91A Birkenhead - Holmlands circular. Route to be standardized with all buses serving Prenton Dell but service reduced to every 65 min
https://online1.snapsurveys.com/intervie...306e2255f3
This probably means that they withdrawn it by next spring!
Wouldn’t exactly call that proposed 91 simplifying it, what a mess plus every 65 mins is a stupid frequency
I had heard a rumour from someone in work (this is a completely unreliable source, I didn’t believe it myself) apparently they had spoke to an Arriva driver who stated that the 418 will operate between Arrowe Park and Birkenhead on a 70 minute frequency. It makes me wonder if that is the reason why the 91 will be rerouted to serve Prenton Dell? Or whether it’s just to reinstate the quicker link between prenton Dell and Birkenhead
Follow me on flickr
Visit this user's website Find all posts by this user
(15/06/2023 20:17)busdude Wrote:  the 418 will operate between Arrowe Park and Birkenhead on a 70 minute frequency. It makes me wonder if that is the reason why the 91 will be rerouted to serve Prenton Dell? Or whether it’s just to reinstate the quicker link between prenton Dell and Birkenhead
The 418 may well revert to The Half Way House... as for the 70min frequency, wouldn't be the first time it's been done on there, it was at least part of the discussion on the last set of consultations.
Typical of Arriva's death by a thousand cuts, might as well withdraw the 418, instead of that barmy proposal.
User(s) browsing this thread: 1 Guest(s)
