Current time: 06/11/2026, 03:16 Hello There, Guest! (Login — Register)
Chester Rail Replacements
Arriva are working the rail replacement service from Chester to Newton-le-Willows calling at Helsby Frodsham Runcorn East then Warrington and Earlestown they are to run until the 4th August
Look like Speke Alexander Enviro 400's are been used
RE: Chester Rail Replacements
(20/07/2019 18:37)trixmax2000 Wrote:  Arriva are working the rail replacement service from Chester to Newton-le-Willows calling at Helsby Frodsham Runcorn East then Warrington and Earlestown they are to run until the 4th August
Will be a direct result of the 699 ending and summer timetables
Who is working the service to Manchester Airport?
(21/07/2019 12:38)mikestone Wrote:  Who is working the service to Manchester Airport?
These are been worked by a coach operator
(21/07/2019 15:47)trixmax2000 Wrote:  These are been worked by a coach operator
Although the station car park at WBQ has been closed Chester-NLW are using the bus stop outside the station and Crewe-Wigan the station forecourt.
(22/07/2019 14:10)mikestone Wrote:  Although the station car park at WBQ has been closed Chester-NLW are using the bus stop outside the station and Crewe-Wigan the station forecourt.
Also the Chester Newton le Willows services are calling at Warrington Central
