Current time: 05/11/2026, 22:44 Hello There, Guest! (Login — Register)
TFGM Subsidised Network Review in April 2020
Following the release of the Forthcoming bus service changes agenda for the upcoming GMCA meeting on 17th of January 2020, Has revealed some shockers of changes proposed to the subsidised network in April 2020.
The areas to receive the worst cuts to services is Oldham and Saddleworth with a lost of a quite few connections and it all to save TFGM money and cut vehicle usage down.
Theses are the proposal put forward for Oldham and Saddleworth
151 Mandley Park - Cheetham Hill - N.M.G.H - Moston - Failsworth - Hollinwood - Curtailed
Proposed new route N.M.G.H - Moston - Failsworth Tesco
343 | Hyde - Stalybridge - Mossley - Lees - Oldham - Route Change and Curtailment
Proposed new route Grotton to Oldham via Cooper Street - Austerlands - Waterhead. Partly replacing the 418 service but no changes to the Sunday Service which will continue via Lees
353/354/355 | Uppermill - Mossley - Heyrod - Ashton/Carrcote - Uppermill - Stalybridge - Ashton - Withdrawn
Officers are purposing to withdraw these services and replacing them with a extended 356 service
356 | Greenfield - Uppermill - Denshaw - Route Extended
Proposed new route Oldham - Moorside - Denshaw - Diggle - Uppermill - Mossley - Stalybridge - Ashton partially replacing the 407 and 353/354/355 services.
403 | Shaw - High Crompton - Rushcroft Circular - Major Revisions
The officers are proposing to revise this service to partly replace the 418 and create it to serve Oldham as Oldham - Shaw - Buckstones - Cowlishaw - Shaw - Oldham serving Royal Oldham Hospital
407 | Oldham - Denshaw - Withdrawn
This route is proposed to be withdrawn and partly replaced by a extended 356 service
418 | Oldham - Royal Oldham Hospital - Oldham - Lees Circular - Withdrawn
The officers are proposing to withdraw this route.
Theses all only proposals at the moment that will drastically affect the already disconnected bus network in and around Oldham. and will no doubt lead to further decline in passenger numbers.
RE: TFGM Subsidised Network Review in April 2020
They certainly weren’t publishing this during the franchising consultation.
(09/01/2020 18:15)iMarkeh Wrote:  They certainly weren’t publishing this during the franchising consultation.
I know crafty buggers they are, what do you think about what TFGM are doing with forementioned routes and why does oldham need a second scenic route to ashton
Suppose what you mean by 'worse cuts'. For instance, under 418 they say
"Service 418 currently operates hourly Monday to Saturday daytime.
Officers propose the withdrawal of service 418 with the northern section (between Dr
Kershaw’s Hospice, Royal Oldham Hospital and Oldham covered by revised service 403 and the
eastern section (between Lees and Oldham) covered by existing services 84, 180 & 184 and
revised service 343.
For further details please see notes under services 343 & 403.
Very few passengers use service 418 to cross Oldham Town Centre, indeed a recent survey of 15
trips highlighted a total of 2 passengers making use of this facility."
If they aren't misleading us then that suggests to me as no journey options will be lost but around 2 passengers in each direction each hour will have to change buses instead of being able to catch a direct bus.
On the other hand under 245 Altrincham-Trafford Centre via Flixton and Davyhulme they say
"Revised timetable proposed where the Monday to Friday, Saturday and Sunday evening
journeys are withdrawn due to high cost per passenger following retender"
So what happens to those who work at the Trafford Centre in the evenings and rely on getting the bus home?
Also worth noting a lot of commercial services are being axed, especially in Wigan and Bolton and in most cases TfGM are saying they will take no action.
(09/01/2020 20:12)knutstransport Wrote:  Suppose what you mean by 'worse cuts'. For instance, under 418 they say
Is there a link available to this meeting agenda. Thank You
(09/01/2020 20:25)dca529x Wrote:  Is there a link available to this meeting agenda. Thank You
https://democracy.greatermanchester-ca.g...2801&Ver=4
All combined TfGM meeting agendas can be found on the same site, with the exception of items the public and press are excluded from.
(09/01/2020 20:12)knutstransport Wrote:  On the other hand under 245 Altrincham-Trafford Centre via Flixton and Davyhulme they say
TfGM's argument is that you could get a 18/23/25/247 to Nags Head and change with a 15 for Davyhulme Road, The 247 for other parts of Flixton and direct to Altrincham, Travel on the 18/23 for Urmston and additionally 25 for Stretford and changing onto a 263 for the remainder of the route.
Unfortunately with both Arriva's loss of tender to the 245, the route change and revert of the 245 and cancellationoof their 18 and ML1 services it is not only disrupted services during the evening but also only helped to transfer customers onto either multi-model or Metrolink tickets if they haven't started driving.
_________________
I have also noticed a common theme with this publications and proposal is that route being changed is well served by similar route along the proposed route for change but back in the old days that didn't matter because it gave people options and made more journeys for them to use
It should also be borne in mind as regards the 245 that the Metrolink extension to the Trafford Centre is close to opening, so this will link into numerous other connections.
Some more proposed April 2020 changes for the next meeting on the 21st February. More changes to services in Oldham with the 402 revised to partly replace services 410, 411 and 412 plus some Oldham-Derker journeys on the 81.
  • 10 Manchester (Arriva): Evening service to/from Brookhouse (introduced October 2019) to continue for additional 6 month trial.
  • 22A (Warrington's Own Buses): The Sunday journeys at 2152 from Newton-le-Willows and 2219 from Wigan proposed to be withdrawn.
  • 79 (Diamond): Sunday service proposed to be introduced between Salford Shopping Centre and Irlams o'th' Heights.
  • 81 (First): Journeys operated between Derker to Oldham to be withdrawn and partly replaced by extended 402 service. Evening journeys operated by Stagecoach continue to/from Derker.
  • 375 Stockport (Stagecoach): Proposed to be withdrawn
  • 402 (TBC): Service proposed to be re-routed to run between Derker and Oozewood via Oldham, Royal Oldham Hospital, Chadderton Hall Park and Royton. Service to run hourly Monday-Saturday and two-hourly on Sundays. Service will run via 410/411 route between Derker and Oldham via Higginshaw except for running along full length of Egerton Street. Service will leave Oldham via 412 route to the hospital before resuming existing 402 route to Broadway, then via Elk Mill roundabout into Chadderton Park Estate before heading from North Chadderton School to Royton via existing 412 route before resuming existing 402 route to Oozewood. Thornham, Royley and Chadderton Way no longer served by service 402.
  • 410/411 (MCT): Proposed to be withdrawn and partly replaced by service 402 between Oldham and Derker. Waterhead served by service 350. Clarksfield and Glodwick no longer served.
  • 412 (MCT): Proposed to be withdrawn. Oldham-North Chadderton School partly covered by service 402. Middleton-Boarshaw covered by service 12.
https://democracy.greatermanchester-ca.g...3858&Ver=4
