Current time: 04/11/2026, 03:50 Hello There, Guest! (Login — Register)
TFGM Subsidised Network Review in April 2020
RE: TFGM Subsidised Network Review in April 2020
The 403 proposal has received an amended to the plans, with the Rushcroft/High Crompton section of the existing route maintained, while the Buckstones section will be withdrawn. TfGM are proposed to re-route the 435 to run a one-way loop around Buckstones, serving Linney Lane to cover the withdrawal of the 403 in that area.
Also will be changes to the 181/182 evening/Sunday services, as First are proposing to run the 182 daytime only between Royton and Manchester, while the 181 will run Monday-Saturday daytime between Royton and Shaw. May be possible that there is a 58 evening/Sunday service introduced between Rochdale and Oldham to cover the loss of the Rochdale-Shaw section.
Also proposed changes to the 115/116 to serve Heaton Park but not serve Dam Head and White Moss estates, while the Ramsbottom/Tottington Local Link is being proposed to be withdrawn.
https://democracy.greatermanchester-ca.g...3859&Ver=4
https://democracy.greatermanchester-ca.g...rt%20A.pdf
